ATF in the crankcase??
Has anyone or does anyone put automatic transmission fluid in the crankcase of an engine?? for any reason??
I'm not suggesting to replace the oil in my new ctd with atf, however I do have this suzuki samurai that may benefit...
I understand the stuff can clean out the gunge in the crankcase. Much like the engine flushes the quickie lube places give. how long do you run it? how much do you put in? am I going to blow my (sapuki) engine??
Had a friend with a chevy 350 with stuck valves. ran 1 quart of Marvel mystery on a oil change and it ran like new. I hear ATF will do the same, theory is it completly will disolve carbon not just knock it loose as some of the additives will do, and plug oil passages. It will also loosen the carbon around the rings and youll probably start to burn oil. I wouldent get to excited about it, but if your down to the last miles on a motor what the heck. I would start with a 1/2 quart on a fresh oil change in the suzi.
I did it to my fiancee's Toyota Celica. It's a '89 with only 28k on it when she bought it. Needless to say, it was never driven enough to break in the engine, and now consumes oil, and was sludged.
Ran 1 quart along with the motor oil at a change, and changed it 1000 miles later, and it did quiet some things down, and the oil was VERY dark when I drained it. Still consumes oil, just not as bad...
Mom's 1990 Maxima with 165k had a noisy lifter, and some ATF did quiet that noisy lifter, is still quiet at 180k... musta freed it up.
It was told to me that ATF is basically just 5wt hydraulic fluid with alot of cleaners in it... makes sense to me.
If you had a noisy lifter etc, I'd try that or some Marvels Mystery Oil, but if there's nothing inherently wrong with the engine other than you think its too dirty in there, I'd not want to risk anything by doing something rash or impulsive to it.
Depending on how dirty you think it is, I'd run a 50/50 mix with your regular oil and a good syn oil on a couple of drain intervals to clean out the engine. Synthetic oil is high detergent and its use alone is often good enough to gently clean out a dirty engine.
I have used kerosene in the crankcase to thin out the goop that formed in the engine when I sunk a boat a long time ago. Kerosene worked great. I did flush the engine out twice immediately afterwards. Engine ran great afterwards. My dad was pretty upset with me though ....
I have a friend that uses ATF in his NV4500 and has for many miles. When he took it apart to check to see the condition in the internals..he found nothing wrong..
Go figure!
Rick
Go figure!
Rick
Originally posted by Shovelhead
You could always check here for an economical higher out-put replacement engine.
Suzuki Replacement Automotive Engines
I use to run about a quart in my old 318 gassers about 500 miles before I was ready to change the oil. Cleaned it up a little and freed up stuck lifters in many a case with the higher mileage engines. If the engine is gunked up real bad, the cleaner could do more harm than good. It could break big gobs of stuff loose and clog up the oil pick up and that is "ungood" as we say.
I would not consider putting it in my diesels though. I run the big A synthetic in my 99 with the dual remote filter set up. Engine stays super clean with that. The old 92, I just change the oil every 5k miles and let it go.
diesel fuel makes a great crankcase cleaner. on a beater engine, pour a few liters in and run the engine at idle/low loads for a little bit [keep an eye on the lube oil pressure gauge] and then drain it all out, put in some cheap [cheapest you can get] oil and run it for a while [week?] and then go back to normal oil...
Originally posted by Dieseldude4x4
Been there done that too.
I would do the diesel fuel thing every weekend, then run cheap 99 cent oil in it in between changes.
We sold that car with 182,000 miles on the original motor. Still ran great.
I took the valve covers off a Chrysler 400 one time and I couldn't tell I had taken them off. The engine was gunked up solid. I don't know how it even ran. We cleaned it up using the kerosene and cheap oil method and put it on the lot and the people that bought it loved it and ran it another six years.
it was this thread that got me thinking about this
http://forums.thedieselstop.com/ubbt...v=#Post1893890
One guy claimed atf is about a 10w30 oil. Any truth to that??
