Another CB ?
Top's Younger Twin
Another CB ?
Awhile back my Cobra 29 started blowing the 20 amp fuse. Instead of trying to figure it out [was not sure where to start] I took it out and bought a little Midland. The Midland did not blow the fuse but the folks at the other end complained often that it sounded like I was on a side band or that it was real noisy. So I bought a cheap Barjan mag mount antenna and that helped...eliminated all the bad sounds. Could the tuned Wilson whip I have/had on there cause the fuses to blow? I ask because I have read about high wattage radios needing special high wattage antennae. Now I am thinking if that was the cause maybe I can put the Cobra back in the truck. Thought I would post before I try...just in case theres something obvious that I need to address. The 29 was tweaked about 12-15 yrs ago but theres no added power going through there but if the coax or antenna is messed can it cause this problem?
Thanks
Scotty
Thanks
Scotty
usually problems with the antenna or coax in the form of shorts or opens will take out the power transitors in the finals. if it caused them to short it could blow a fuse. you could test it on the bench with a power supply and a dummy load. if it still blows the fuse you know it's the transceiver.
Top's Younger Twin
I saw new Cobra 29's for sale in Fargo ND for 99.00. Is that a good deal?
I was thinking about getting the model with the weather bands too. Christmas is coming and I think all I need to do is let my wife know what model. Any suggestions?
Scotty
Ls1z28fbody
11-27-2006 08:03 PM
snowrodeo
10-09-2006 09:11 AM
Jezzhuntin
08-25-2006 02:51 PM
