AMS Oil
AMS Oil
Ok here is one for you guys that use AMS Oil; a friend of mine has a 2001 Durango 4x2 with the 4.7. He as run AMS Oil since the car had 6k on it and has followed the ams oil scheduled program to the letter. The car has 75k on it now and the engine seized and broke into pieces and punched a hole in the block. I always thought running a long time on oil was a big mistake. I might also point out the car has never pulled anything and was babied.
Well no matter how good or bad of an oil that it may be having an engine failure in 75k isn't just due to the oil. Something was either wrong with that motor or it was drove around with 1qt in it. He probably could have never changed the oil from the 6k to 75k and that wouldn't have happened if nothing was wrong with the motor.
Originally posted by Lary Ellis (Top)
Of course the dealership wants to blame it on the oil
I had a buddy that had LP and IP problems on his 98 24V....Dodge blamed the Howes Lubricator he was using....lol.
i have used amsoil for as long as i can remember 250K on my cummins and its been run hard all the time and the 727 automatic has had amsoil in it since new and is still going and still towing with an engine thats fuel pump is turnd way up ... the oil gives you an edge in hard use but you still need to change it i would say something other than the oil is at fault!
Re: AMS Oil
Re: Re: AMS Oil
Originally posted by Jeepin951
Wait a second, he ran the Durango for 69K miles without an oil change? Am I reading this correct?
