Air cooled VW gurus?? Electrical question
I am rebuilding a sand rail which currently has a VW engine and I am at the wiring stage. It has been converted to an Alternator and I know the B+ post goes to the battery but everything I read about the D+ post says it must be wired to an indicator light and then to the ignition switch accessory port to make it charge. Is this true and if so, how do I get around this?
Reaching back into memory here, that's the field wire...The circuit serves as an exciter for the alternator to work...It needs to be connected to a switched, ignition-on terminal...If, for some reason, you don't want the light you can use a resistor with the same properties......Ben
Hook up the light. Just because it lights doesn't mean you have to look at it.
Incandescent lamps have a dynamic to their resistance. It goes up when they heat up.
If it is just that simple I have no problem hooking up a light. I do have a little green indicator light that I can mount.
Thanks for the replies!
Make sure you use an incandescant lamp and not an LED, like he said, lamps have a cold and hot resistance.
You need to match the type of lamp specs a newer mini lamp would have a different milliampere rating than an automotive indicator lamp.
Is it a Motorola, Bosch or chinese alternator?
own1bigtruck
07-05-2007 08:16 PM
nymegacab
06-11-2007 02:50 PM
