1993 jeep front end shaking
Hello i have a 1993 jeep and when i get up to around 70 kmh my front end starts jumping all over the place. im pretty good with cars and iv gone underneth to look for anything broken or loose even have rotated the tires but there is nothing, balljoints are tight tyerods are good even the track bar also no play in the braings can someone help please.
if any one can help they can email me at littleniss2004@hotmail.com
no mods just stock all the way but i did talk to the dealership and they said it could be the shock in the front for the link bars and i did notice that there is oil leaking out of it today and was not before this started the history is the vehical was well maintained
I must have missed it. Is this a YJ, XJ or ZJ? Big difference in suspension setups. Have the tires been balanced? I've had wheel weights fall off causing new found vibrations. Have you checked the unit bearing(s)? Great idea on checking the driveshafts. Remove the front driveshaft and go for test drive. When removing the rear driveshaft for test drive make it a short trip around the block. The transfer case will leak ATF.
Like mentioned in the post above, check to make sure your tires are balanced, and there are weights on each rim. We had a similar problem with our 89 Comanche, we would be going down the road, and it would just start shaking. We finally figured out that we had gotten enough mud in the rim that it was making the tires unbalanced, a little bit of spraying with the water hose cleaned it right up. Check the small stuff, like I mentioned.
Somthing to think about if you go mudding dont forget to wash the backs of the tyres.And check your steering stabliser this looks like a shock on the front end.
i think i have it
i went under my jeep today and found the shock that is to stabilize the steering is blowen i have oil from it all over so i ordered the new shock will see if it is the problem today the part is in i just have to go get it. THANKS eveyone for the advice!
i found the problem thanks
Hey thanks all i did replace the shock for the steering and yes it did fix it the bottom of the shock had a hole all the oil leaked out but was fine the day before. when i changed the breaks so didn't think that was it.!
1993D350
03-24-2011 07:52 AM
