odd codes,truck not running right
i already posted this in the engine tech section with no response so i thought i would try here
getting these codes
p0633,p0602 and p0107
they all came on in in a matter of 1 week,and i cant clear 2 of them with my diablo.i alredy used the search but there really wasnt any definative info.it starts and runs fine but under acceleration it will buck once at about 2k rpm then it seems to lose power,if i roll on the gas slowly it accelerates fine???i have already looked at the wiring for the MAP sensor code and it is clean with out ant corrosion,i also removed the edge programmar to eliminate any issues with that,i guess i should put the stock file from the diablo in it as well.any thought would be appreciated
__________________
getting these codes
__________________
Cummins Guru
maybe your diablo, "i also removed the edge programmar to eliminate any issues with that,i guess i should put the stock file from the diablo in it as well.any thought would be appreciated"
well i took both programmer's off and cleared all the codes,drove it for about 15miles noticed it was very low on power,then the check engine light came back on,same codes,map,secrest key,turbo over boost,ect.took it to the dealer they did an update reflash of the ecu,got in it,noticed same lack of powe and about 10 miles later same codes.now before i go and spend money on an ecu do you really think that will solve the issue?or should i keep looking for other problems first?any opinion would be appreciated
ocsurf16
03-05-2007 11:34 AM
vess33
09-19-2006 08:55 PM
