Nothin' But Trucks- Truck Pull/Show May 7th Hastings Michigan
There will be a truck pull and truck show May 7th in Hastings Michigan at the Barry County Expo Center
I'm not sure what time everything starts but will post as soon as I know.
Hope to see you there!
It also has a Different (better) sled than last year. The sled is owned by NearPass.
Pulling starts at 9AM. You need to be there for the drivers meeting by 7:30-8:00 to register.
Hook fee is $20.
There will be 2 classes, Factory Diesel & Modified Diesel. I will post the rules as soon as I can get them.
The pulling trucks will automatically be part of the show-n-shine as well.
There will be a burnout contest that costs $20 to enter, and also a "tough truck" course that is a $20 event as well.
Hook fee is $20.
Rules for modified are like this:
1. ALL TRUCKS WHO PLACE IN THE MONEY WILL BE TECHED!
2. 8000 lb
3. No Nitrous, Propane, Alcohol, etc. #2 Diesel Only
4. No Water Injection
5. Hanging weights allowed, furthest point must not exceed 60” from C/L of front axle
All weights must be secure; disqualification may be enforced if weights fall off.
6. Must have full interior, exterior. Has to remain street legal
7. Must provide license and registration
8. Single Charger only limited to maximum of 2.8 Chargers will be teched.
9. DOT tires, no studs, no cut or sharpened tires.
10. No aftermarket transfer cases or transmissions.
11. Rear suspension must have a minimum of 1” of travel.
12. Must pull from Reese style hitch or factory bumper. Hook point must be at the
furthest most point of the vehicle. Hook point must be at least a 3” OD ring or clevis
13. 26” Hitch Height
14. Traction/ Ladder bars allowed
15. Exhaust must exit straight up or straight down or have muffler
16. No aftermarket heads
17. Engine must be out of factory 1 ton or smaller pickup
18. Bellhousing blankets required for engine turning over 4200 RPM.
19. Drive Shaft loops recommended
20. Track and Tech official’s decisions are FINAL
2. 8000 lb
Originally Posted by Red Stroke
You are sure about the 7th thats a Sunday seems Odd?
What are the street stock rules?
I see your sig is missing after your first post?
Here is a quote about the street stock:
"Stock is just a local guy thing, no turbo pump or anything more than a chip or fuel plate. Any more questions post away."
Not sure about the sig.
So can a truck with those mods and a adjustable chip back to stock run in the stock class, also how do you tech a p pump to verify it only has a plate in it. I am just asking because I am setting up a similar pull and was wondering how you are doing it. We were thinking of making one of the stock class rules, trucks allowed to emit gray haze and no black smoke or it automatically jumps up to mod diesel class? Or are you just running the rules loosly, thats fine but in my case the more years the more rules you need.
xXHoPXx
18
10-08-2010 06:13 AM
coreydr2003
Competition / Pulls / OffRoad
16
05-17-2008 10:10 AM
getblown5.9
16
05-07-2007 01:21 PM
