View Poll Results: How many Chapter #33 members
Voters: 44. You may not vote on this poll
Maryland Chapter #33 Never ending thread V
#1216
Let me know if you want it......Been dieing for a reason to install the isspro...
#1218
I got little box today for the truck.
Edge Juice W/ Attitude... I know it is not the huge HP stuff but it is a start.
I opened it up and the wires. Have you guys installed these before? I know for sure the EGT tap will be an issue for me. Meaning I don't want to screw it up. I know there is a lot going on with trannies and stuff. Let me know if there is a time available.
Thanks...Peace!!
Thanks...Peace!!
#1220
i ran a edge hot juice stacked with an ez for about 10 months i put down 507hp with it thing pulled a sled pretty well to. there are guys with edges that are running 600-700 hp they are nothing to sneeze at. i can give you a hand hooking it up took me all of 10 mins to do mine.
#1221
I've got a BD brake and love the hell out of it. I haven't towed a trailer with it out east but look forward to it when I get back home. Hauled enough in the bed a few times to make her really squat and liked the performance. I use the brake all the time empty too. Guys at the Cave® helped me put in on. Only took a few hours.
#1224
I bought it used on either DTR or TDR (can't remember). I paid $500 shipped and I have a 5 speed. Stick mounted switch too. I remember reading that the BD supposedly has more lower RPM braking power. If you are going to put in on a 12 valve, remember that you need to update your exhaust springs too.
Hope that helps,
Jason
Hope that helps,
Jason
#1225
you upgrade to 60lb ex.? y? i also read you cant use it when i have my gear vendors engaged. i dont understand that,whats the diff between me using my brakes and using an exhaust brake?
#1226
THE EDGE JUICE IS AN EASY INSTALL!!
If you have at least SOME skill at automotive stuff and can read directions, you wont have a problem. The drill and tap was intimidating for me too, I got half way through and a friend of mine squirted me with a garden hose (let that be a lesson to not do this at a firehouse), so I had a mechanic buddy finish is off.
Don't be afraid of anything else. The install is very straight forward and you will amaze yourself hoe simple it was. You can save the EGT probe till later, it doenst have to be put in at that exact time. I left mine attached and just zip tie out of the way till i got the tap and die set.
#1227
Plus,..... they're cool.
#1228
If I can make it back down to the Cave one of these weekends you are more than welcome to try the truck out.
Jason
#1229
awesome i should be back up there shortly to do a clutch install if Mr. scott will grant me permission to use his garage. how did the tranny work out for you guys?sorry i had to leave the g/f had to do a private party (bar tending)
#1230
Anything going on at the cave on Sunday(3/16)?? The 8.8 is in the jeep and now it is time to pay some attention to the Dodge. If so I have a Edge and a 2" leveling kit that would love to go in. I want to give myself a early Bday present...
