View Poll Results: How many Chapter #33 members
Yes i'm an active member
45.45%
Not active but a member
11.36%
Not a member just lurking
31.82%
Member of other chapter
11.36%
Voters: 44. You may not vote on this poll
Maryland Chapter #33 Never ending thread V
Old 03-08-2008, 07:51 PM
  #1141
P.J
P.J's Avatar
Sure, but, Scott could write "Travis", is T.J's trailer a dually?
P.J is offline
Old 03-08-2008, 09:15 PM
  #1142
lukedaemon's Avatar
Originally Posted by 06 DIESEL
IIRC he got it from Rock Creek Hardware in Rising Sun, MD and they had literally tons of trailer parts there. I think that they had axles there, but I am not sure. There is a few companies on E-bay that sell axles, you might look there also.
I will check there. I was there once looking at trailers. Kind of forgot they had trailer parts. I didn't know there were axles on ebay. I'll check that now.
True, but I can answer for him
I figured you could get the message to him as well.
lukedaemon is offline
Old 03-09-2008, 09:54 PM
  #1143
crabbelle's Avatar
ho wmuch wieght do you think i would have to add to be able to TRY and compete in dirt drags. LOL
crabbelle is offline
Old 03-10-2008, 08:50 AM
  #1144
Crabjoe's Avatar
Anyone know what might cause the turbo's whistlin noise to disappear?
Crabjoe is offline
Old 03-10-2008, 09:03 AM
  #1145
paroxysym's Avatar
clogged air filter? you sucked in a bird?
paroxysym is offline
Old 03-10-2008, 09:28 AM
  #1146
TKC2000's Avatar
does it not make noise at all or does it fade out as you're driving?
are you the only one to notice this? could be you've burned out that aural frquency in your ears from it being so loud and listening so long...
TKC2000 is offline
Old 03-10-2008, 09:54 AM
  #1147
Crabjoe's Avatar
I only get a slight whistle at 15-1700 rpms. Past that nothing.
Here's the story on this. I was over at Travis's and talking to him about fuel mileage the other night. I was telling him I can hear the turbo whistle as low as 1400 rpms, and I have been able to in the past.
Over the weekend, I picked up a Dingo (total weight was about 2000lbs w/trailer), and I noticed a significant loss of passing power. This made me listen for the whistle, which in the past used to drive me crazy.
So I've been thinking my LP was going out because I've been noticing a loss of power since last fall. I did check my air filter back in December, and it was all good, so I never thought it was a turbo issue, but now knowing I don't hear the whistling above 1700 rpms I'm thinking I might have a boost issue. Today, I couldn't hear the whistle at all.
Anyone know if a turbo issue will cause a Check Engine light?
I guess I better pull the filter and run it to see if there's any difference. I've got a new filter on it's way from Geno's so I hate to try and run the motor without one, but it's driving me crazy now.
Crabjoe is offline
Old 03-10-2008, 10:09 AM
  #1148
06 DIESEL's Avatar
Don't run it without a filter. Wait for the new one to come in unless it is really really bad. I have a used one that you could borrow if needed, it has about 15k on it.
I know that it might have been said before but you should think about getting gauges on it so that you can better identify your problems. With an automatic I would get Boost, FP, Trans temp, and EGT. I am sure that Lloyd could hook you up with a set since he is a chapter member, DTR advitiser, and a great guy.
06 DIESEL is offline
Old 03-10-2008, 10:12 AM
  #1149
rollincoal02's Avatar
No, the only turbo issue that will set a CEL is an overboost code (and even those don't do it usually) But if you are having loss of power in the upper RPMS it could very well be a fueling issue. If your lift pump is bad and the truck isnt getting the fuel then you aren't gonna be making the boost you should be which means the turbo is going to be quieter.
check your fuel pressure first and foremost, as well as I think the 04's can do that key on-off trick 3 times and see if any other codes come up
rollincoal02 is offline
Old 03-10-2008, 10:20 AM
  #1150
Crabjoe's Avatar
Anyone got a fuel pressure gauge to check my fuel pressure?
Thanks.
Crabjoe is offline
Old 03-10-2008, 10:41 AM
  #1151
scottsjeeprolet's Avatar
About 10K#
Dae i have some gauges in the Cave to check the FP.
scottsjeeprolet is offline
Old 03-10-2008, 10:50 AM
  #1152
paroxysym's Avatar
speaking of gauges, travis where did you get your 90 fitting for your fuel pressure regulator thing.
Old 03-10-2008, 11:36 AM
  #1153
06 DIESEL's Avatar
I had an extra one that is now in the surplus parts at the cave.
Old 03-10-2008, 11:40 AM
  #1154
paroxysym's Avatar
i suppose ill check next time im over there... any ideas where to pick one up as a back-up?
Old 03-10-2008, 01:18 PM
  #1155
Crabjoe's Avatar
Will there be a gathering at the Cave this weekend? I don't want to put anyone out just to check my fuel pressure.
Crabjoe is offline
Quick Reply: Maryland Chapter #33 Never ending thread V
