View Poll Results: How many Chapter #33 members
Voters: 44. You may not vote on this poll
Maryland Chapter #33 Never ending thread V
#574
They are not the only one's with a group buy currently, I am not a member over there but thanks for the info.
I had some wierd stuff happen on the way home last night. I never threw a code but here are the symptoms. RPM and Speedo dropped suddenly and the ABS and Brake light come on and cruise was kicked off. I pulled off the interstate shut her down and check for codes, none. I pulled out the predator and checked for codes that way and still none. Started it back up and the lights were off. Cruising along and it does it twice more, I did not stop these times, just kept going but it did not kick off the cruise the second two times, only the lights came on and it beeped at me, but still no codes. Anyone have any idea what this might be?
#575
I wondering if it could be a chaffing wire harness or something since you didn't have these symptoms before the accident and subsequent tear down and rebuild. I know you were pretty diligent in keeping track of what the shop was doing, did they have to take apart much, if any, of the harnesses around the engine? I know that if I hit a good size bump with the cruise on it will sometimes kick off, but there are no lights . I think it happens more when the rear tires break contact with the pavement because of the severe jolt.
#576
#577
The slipping clutch could be the problem. I know that when in cruise mode that if the engine suddenly revs up, as with the tires bouncing off the pavement, it will kick off. Maybe the same thing for a slipping clutch?
#578
Probably related to the clutch, it sees a spike in RPM and no raise in wheel speed from ABS sensors and it confuses the truck.
You gonna have a clutch before April 24?? LOL
#580
I will definately let you know, I know of a few group buys going on currently, I am going to talk to them and Lloyd and see what they can do for me. What are you looking for? I am going with a SBC DD 3600 either a con ofe or a sprung hub, not sure about that yet.
#583
Thanks TJ, let me know.
I think that the con fe is noiser and grabbier than the sprung hub but I am not sure, I am basing this on what I have heard. TJ would know more than me about the difference.
#584
con fe is a single disk clutch, bobby, what do you plan to do with the truck, and how much power are you looking to make in the future.
there are solid hub and sprung hub dual disc clutches now, the sprung hub DD are a little less grabby for street driving and towing, but the cost goes up a bit for them.
#585
im looking to make about 350hp i need the daily drive and towing ability. all im ging to do is the turbo i bought, injectors and bump the timng and im done. im going to be hauling crab pots and towing for rosedale attractions (carnival) so towing is a major thing, but i have to keep in mind the 110 miles each way to baltimore-philadelphia. so what you recommend. i trying to keep my budget to about $1,000
