View Poll Results: How many Chapter #33 members
Yes i'm an active member
45.45%
Not active but a member
11.36%
Not a member just lurking
31.82%
Member of other chapter
11.36%
Voters: 44. You may not vote on this poll
Maryland Chapter #33 Never ending thread V
Old 01-02-2008, 12:26 PM
  #556
scottsjeeprolet's Avatar
I don't have one maybe another member might? Jason (Geis) you have one?
did you tell the guy he works right in front of the Cave?
scottsjeeprolet is offline
Old 01-02-2008, 03:12 PM
  #557
skynyrd's Avatar
I have a gear puller set TJ
skynyrd is offline
Old 01-02-2008, 03:30 PM
  #558
getblown5.9's Avatar
scott, we can make one fairly easily, the thread for the gear match the threads on the intake horn bolts, then all you need is a piece of metal with two slots that can rest on the end of the pump shaft and pull the gear off.
if you want to make one at work i can pull my breather off tonight and take a measurement or two and make a drawing for it.
getblown5.9 is offline
Old 01-02-2008, 04:43 PM
  #559
ramsport59's Avatar
I used a steering wheel puller on mine TJ, a little tight fit but it works.
I finally pulled mine off and is going in to be tested out.
Rick
ramsport59 is offline
Old 01-02-2008, 04:48 PM
  #560
gies's Avatar
I borrowed one. Hope it all works out.
Looking at an 05 with the G56. Very tempted!! 36K miles...
gies is offline
Old 01-02-2008, 06:01 PM
  #561
Well i have a steering wheel puller set, just didn't think there would be enough room to get it in there.
Old 01-02-2008, 06:45 PM
  #562
Originally Posted by crabbelle
this is a nice deal https://www.dieseltruckresource.com/...ct=15714&cat=8
its exactly what dave told me to get but just not a whole turbo. the upgrade is about $250 but for another $250 i could have this turbo and use my currently one has a spare or sell it. plus theres a set of marine 370's on ebay so far $100
http://cgi.ebay.com/ebaymotors/dodge...QQcmdZViewItem. if i got these two things and bumped my timing i would be done with what i wanted to do performance wise. minus a clutch . so what would you guys do? im not breaking the bank too bad.
It looks good. Don't forget to notch or drill the center divider in the turbine housing so the wastegate. That lets the wastegate vent all 6 cylinders instead of just the rear 3, keeps the boost from getting out of control with big injectors.
wannadiesel is offline
Old 01-02-2008, 09:11 PM
  #563
crabbelle's Avatar
do you think those 370's will be ok with towing?
crabbelle is offline
Old 01-03-2008, 10:19 AM
  #564
TKC2000's Avatar
Found this on Craig's List
http://baltimore.craigslist.org/car/516699956.html
even though it's a Ford, I thought you Ravens fans would get a kick out of it.
TKC2000 is offline
Old 01-05-2008, 05:35 PM
  #565
crabbelle's Avatar
who all is going to tnt dyno day? they setup they dyno to run duallies with both duals.
Old 01-05-2008, 05:44 PM
  #566
Depends on how you set up the pump.
Old 01-05-2008, 05:59 PM
  #567
crabbelle's Avatar
like timing wise? i was thinking something like 15.5
Old 01-05-2008, 06:03 PM
  #568
No, where the plate is set and how you set the star wheel.
Old 01-05-2008, 06:08 PM
  #569
crabbelle's Avatar
o, ok yeah im thinking i may have slid it back some
Old 01-06-2008, 12:33 PM
  #570
06 DIESEL's Avatar
I am getting ready to head back out there, going to try tp drive straight through again. I got some good carnage pictures from a Pro Stock tractor out of PA, lets just say that there is not much left of the tractor and I almost got hit by a piston
TJ, I am picking up your weights, I will try to meet up with you this week to get them to you.
Anyone want to donate some money to the "Travis needs a new clutch fund"? I can not hit resume on the cruise without it slipping now, she has been turned back to stock until I get the $$$ for a new one.
06 DIESEL is offline
Quick Reply: Maryland Chapter #33 Never ending thread V
