Looking at a 2010 DRW SLT model
I am in the market for another dually and really like the look of newer Rams. I found one for $20k with 183k and a new manual trans, tires and clutch (guy used it to pull a 3 car trailer all over the East coast) What should I be looking for with this truck as far as problem areas or topics of concern?
At that mileage I would be concerned about a number of things....Bushings, shocks, brakes, wheel bearings etc...
Does it have a new clutch? Is the motor making any noises? Is the rear end all in good shape as far as the gear and bearings?
Other than normal wear-and-tear items as mentioned above you should be fine. Sounds like a good deal to me. Since it's out of warranty, I'd definitely do the deletes if you can.
I may be mistaken, but I don't think the H.O. models were available until 2011 and with auto only.
Sent from my DROID X2 using Tapatalk 2
Just programming, 600 vs. 650 ft/lbs of torque. The stock clutch apparently couldn't handle more than 600, so in a strange twist of events (compared to earlier years) the auto was rated higher than the manual. Easily fixed with aftermarket parts though I hear.
gpshemi
31
07-10-2009 06:59 AM
RedRam410
02-02-2007 10:27 AM
