wont shift out of first
Old 04-26-2010 | 02:17 PM
zmann's Avatar
I have a 47re. When i take off my truck sticks in first, to get it to shift i have to pretty much floor it and let off, but then it skips second and goes straight to third. If i have to take off fast i cant do it. Any thoughts??
Old 04-26-2010 | 06:06 PM
ado2b1's Avatar
Pressure sensor and pressure governor solenoid would be a rough guess. I think that typically affects the second to third shift though. Normal for 1-2 and 3-4.
Old 04-28-2010 | 07:38 AM
Stamey's Avatar
It may be the speed sensor in the transmission/transfer case. When this happened on my 99 I swapped the speed sensor from my 96 into it and it shifted fine. Since you may not have two trucks with a 47RE, you might have to buy one and try it. They aren't expensive, and available at most parts places. Note: you have 2 speed sensors. The one in the rear axle runs the speedometer, and the one in the transmission has an effect on the shifting.
Chris
progrower
20
06-14-2014 08:17 PM
i8yr5_0
05-17-2011 11:42 PM
rustydeeretech
06-16-2010 09:41 AM
needaram
06-15-2009 10:09 PM
97catintenn
08-24-2005 06:01 PM
Quick Reply: wont shift out of first
