which wire is the tach wire?
Old 02-06-2006, 05:09 PM
AAmeeting's Avatar
DODGE, RAM PICKUP, 2001, Tachometer
Diesel tach wire is gray/black. The wire is located on the center of the firewall. There are two black plugs, the wire is in the top plug without the white insert. The tach wire can also be found at the ECM on the passenger side firewall in connector C-1, pin 8.
close
I work for Circuit City. Some installers are a little green. Hope this helps, Its from DEI.
Old 02-06-2006, 09:16 PM
AggiePhil's Avatar
AAmeeting is right, and he is echoing what I said in an earlier post. Tap the wire at the connectors at the top of the firewall, under the hood.
Old 02-07-2006, 06:56 AM
Txwelder's Avatar
Thanks for the info. I will print it out and take it to him so he can get it done. I really appreciate it and will get back to you with info on how it goes.
Old 02-07-2006, 01:29 PM
AggiePhil's Avatar
This is the harness where you will tap the tach wire.
Old 02-07-2006, 04:06 PM
AAmeeting's Avatar
And Wait to start.
Old 02-09-2006, 11:11 AM
Txwelder's Avatar
Turns out it wasnt a wiring issue at all. The tech didnt program the xmitters like he was supposed to so only one worked. Then trying to use the other scrambled something so they went back in and the suppervisor got it all done proper. Thanks for the help.
Old 02-10-2006, 09:33 AM
lglamb's Avatar
hmm... wonder how he tapped the tach wire that he
couldn't find.
Old 02-10-2006, 10:03 AM
AggiePhil's Avatar
Yeah, I think you got lied to about it not being a wiring issue. From your description of the problem, it sounds like it was DEFINITELY a wiring issue.
Old 02-11-2006, 10:32 AM
Txwelder's Avatar
Main thing is they got it taken care of and compensated my gas money for having to come back three times. Im satisfied.
Bradleysram
19
05-12-2009 08:36 AM
dodgestang
11-04-2007 01:29 PM
poolboy
12-18-2002 02:38 PM
poolboy
12-18-2002 08:00 AM
TPilaske
16
11-22-2002 08:15 PM
Quick Reply: which wire is the tach wire?
