Where is my CPK!
Re:Where is my CPK!
I don't know if this will help from the 2003 service manual:<br><br>"CRANKSHAFT POSITION SENSOR DESCRIPTION<br>The Crankshaft Position Sensor (CKP) on the diesel<br>engine is attached at the front / left side of the<br>engine next to the engine harmonic balancer."
Re:Where is my CPK!
http://www.dodgeram.org/tech/dsl/mt_...l_sys_comp.htm<br><br>I don't think you have a CKP (Crankshaft Position Sensor). You have a CMP (Camshaft Position Sensor). #11 in the above link.
Guest
Posts: n/a
Re:Where is my CPK!
Smokedog I believe you are correct. I found the Cam Posistion sensor but I dont know if that is really the problem.<br><br>I talked to the ******* in Corpus and he told me there is a timing solenoid in the injection pump and there is no CKP.<br><br>Im taking it to a dealer in Odem to get my money back on the CKP and have them hook it up to the computer.<br><br>-Goin down the road power stalls - tach keeps working. Truck can still drive but has no power. It recovers in a few minutes and it may not happen again for 2-3 days.<br><br>Only code I can pull up is 1693 - DTC code in ECM.<br><br>I love my truck but its sending me to the poor house.
Re:Where is my CPK!
[quote author=BigBlackDodge link=board=13;threadid=9265;start=0#88953 date=1041876676]
[/quote]
If that's the only code coming up,
you might see if the Dodge Dealer can recommend you to a Cummin's shop.
They know the engine just a wee bit more than the techs at Dodge do , and might be able to find the problem quicker.
phox
[/quote]
phox
Re:Where is my CPK!
Your problem is systematic of a CKP. With the 1693 code, though, it could be something as simple as corrosion inside the wiring harness connectors. Also, it could be the APPS. You could try the calibration routine on the APPS and see if it helps. Since the tach isn't dying, I'm thinking this may be your problem.<br><br>Disconnect the batteries for about 20 minutes. Then reconnect the batteries. Turn the key to "on" but don't start the engine. Slowly depress the accelerator pedal to the floor and then slowly release the pedal. Start the truck. The Accelerator Pedal Position Sensor can cause the problem you are having. Let's hope it's not the problem because they are a little pricey.
Re:Where is my CPK!
[quote author=Smoke Dog link=board=13;threadid=9265;start=0#89304 date=1041939932]<br>Disconnect the batteries for about 20 minutes. Then reconnect the batteries. Turn the key to "on" but don't start the engine. Slowly depress the accelerator pedal to the floor and then slowly release the pedal. Start the truck. [/quote]<br><br>I thought you had to disconnect them for at least 30 minutes?<br><br><br>phox
Guest
Posts: n/a
Re:Where is my CPK!
I did the APPS recallibration when I put in my hydro boost and it seemed to run fine until it stalled again and engine light came on the next day.<br><br>Went to dealer and he pulled up a bunch of codes.<br>Injection timing (maybr from PnP)<br>Boost sensor<br>and the list goes on.........<br><br>He emptied the codes. I left the BD PnP off.<br><br>Truck at low speeds acts like its running out of fuel. Real fast sputter. But not all the time.<br><br>It will also do it on real hard accelleration. Sometimes.<br><br>At 55 in OD it will also do it. Sometimes.<br><br>Went back to dealer to read codes and there were not any. Except for Trans relay. <br><br>Dealer doesnt know the problem cause he cant find any codes. The APPS should leave a code. But then again what evers causing the problem should leave a code. <br><br>Injection pump has only 25,000 miles on it.<br><br>Im at wits end!!!! :P
Re:Where is my CPK!
BBD, I'm thinking with all these codes popping up, you either have a dirty ground wire connection or a wiring harness that's loose or has corrosion in the connector. Take your connectors apart and spray some contact cleaner in them and put them back together.
Re:Where is my CPK!
[quote author=richard link=board=13;threadid=9265;start=0#88920 date=1041872532]<br>Go to the tech facts section, click on 24v isb, Cattle Hauler wrote a step by step with pictures. Hope this helps.<br>[/quote]<br><br>Actually, that was moved to the articles section a while back. You can find it here <br><br>https://www.dieseltruckresource.com/...es/cps/ckp.htm<br><br>Step by step with pictures, just like you said.
