Where cam I get a pump tested VP44
Old 08-01-2004 | 09:38 PM
dieselman24's Avatar
my buddy just took his pump off and needs to get it tested to see if it is any good or not truck just started to loose power real bad then died never would start again and the lift pump was dead too Thanks TJ 573 578 5000
Old 08-01-2004 | 09:47 PM
Smkndzl's Avatar
you will need to call your local Cummins Dealer and ask them who the authorize Bosch pump shop they use is , and most of them now do VP44 pump work.
Old 08-02-2004 | 12:18 PM
Just called dealer and he said *out of luck put it back on and check it..Thanks for the help though..TJ
Old 08-17-2004 | 10:12 PM
jdeereboy's Avatar
I took my VP44 off and took it to a ADS shop here in NC. They tested it and called me with the results of it needed to be rebuilt and a qoute for the job.
The Cummins shop should have recommended you to an ADS shop. If you can do without the truck for a week or so, I would recommend sending it to the shop I took mine to. If you are interested, I will give you there number.
My complete rebuild with all the latest improvements including a complete new housing was $670. The also just rebuilt an injection pump for my Ford truck with a 6.9. I trust them completely.
Kevin
Tobin
03-18-2009 08:41 AM
Cspotrun
125
11-07-2007 07:16 PM
TorqueJunkie
02-01-2007 11:45 PM
Jonsey
10-09-2004 05:28 PM
gamiller31
09-10-2004 07:15 PM
