Were are the power door lock wires located under the dash?
Trying to install keyless entry in my 01.
Seems pretty easy, except I cannot find the Pink/Violet and Orange/Violet wires, which are lock and unlock for the life of me.
I tried to find them behind the kick panel, but couldn't get to them or see it it. Searched high and low.
Are these in the large main harness? Or were?
If I could just pull the door panel and run a wire through the panel, I would, but it looks like there is plug in there.
Found them
Above the gas pedal against the firewall. What a PIA to get to.
Got it in though.
Found out Orange/Violet is lock and Pink/Violet is unlock. Had it backwards at first.
Not to hard of an install. But took some time.
Got it in though.
Glad you found them.
I had a hard time finding them the first time also. Didn't help that my Factory Service Manual showed them in the wrong place.
I spent hours popping off the door panel and trying to run two more wires before giving up, there just wasn't enough room in the loom for them.
unioncreek
08-16-2013 01:22 PM
staarma
0
10-25-2007 01:49 PM
