VP44 CRAP!!! need some advice
Old 03-10-2004 | 06:28 PM
Diesel-Dan's Avatar
I am in the middle of replacing a VP44 on a friends truck. I was removing the puller from the gear after the pump was removed. The gear seemed to move quite a bit and now i dont know if it can acctually jump time with the cover still in place or not. Can some one please help me with this so i can put the pump back in this thing...or am i going to have to pull the fnt cover to get the gear back in time? I just dont see the gear having that much play and comming free from the other gear. And the directions and people i taked to never said anything about moving the gear....so i dont think its a big deal. Thanks!
Old 03-10-2004 | 08:39 PM
59Dsul's Avatar
I'm giving you a bump for those who look at the most recent posts. Anyone?
Old 03-10-2004 | 08:47 PM
MnTom's Avatar
Isn't the shaft for the VP a keyed shaft? If it is, you should be able to line up the keyway from one to the other.
Old 03-10-2004 | 09:11 PM
J BODY's Avatar
No big deal dan!!! press on you're doin fine!!! The gear will not move enough to "jump" timing.
Old 03-11-2004 | 10:26 AM
Diesel-Dan's Avatar
That is what i needed to hear. I just didn’t want to ASSume on this billion dollar (grossly exaggerated!) install! Thanks for the bumps and info!
Dan
duckbuster23
05-23-2011 11:20 PM
13ALPHA
01-28-2008 09:35 AM
bsj04
09-20-2007 08:09 AM
ryan466
08-30-2006 10:10 AM
Quick Reply: VP44 CRAP!!! need some advice
