vibration in the first injector line on driver side
Old 12-09-2010 | 04:03 PM
loya 3500's Avatar
Question vibration in the first injector line on driver side
My truck has been doing it for about a month and have not really worried about it to much. beacuse it has not efected the running of the truck.
there is a vibration and a ticking noise. in the first injector line on the front driver side of the engine.. you can not feel the vibration unless you touch it. but you can hear the ticking all the time..
what could the be the cause of this? bad injector? they are stock with 171k on them
Old 12-09-2010 | 11:02 PM
iforge03's Avatar
do you have the little blue injector line brackets on in the correct location. if these are not in the right place your lines will vibrate and eventually wear out
Old 12-09-2010 | 11:09 PM
loya 3500's Avatar
it is more of a pulsing/vibration along with a ticking all the time and there is no clamp on #1.. line
Old 12-09-2010 | 11:48 PM
jhenson's Avatar
Probably wouldn't worry about it too much....my '03 has done it since new and now has close to 300k on stock injectors. I too wondered about it right after I bought it but for once the service dept at the dealership was right....said it was nothing to worry about, they all do it. I left it at that and so far no problems.
Now I guess I better go find some wood to knock on .
JQmile
06-08-2011 10:41 AM
loya 3500
12-13-2010 03:19 PM
willTX
10-05-2008 01:51 PM
cumminsho2500
09-07-2003 11:45 PM
atc250r
08-26-2003 09:52 PM
