truck won't start after pump seal!
Just got done taking the pump off my completely stock 89 diesel. Locked the pump, took it off, put on a block seal, the two green oring seals on each side of it and an o ring about the kill switch screw in deal. Put it back on, hand primed it and it wont start. I cracked an injector line and it is barely putting out any fuel, just a trickle. What's up with my pump!
It sounds like you pulled the head off too far and the drive coupling for the rotor came apart. Take a look in the 1st gen sticky for pump rebuild info...
what are you calling the drive coupling for the rotor? I made sure the piston notch was keyed correctly. But i think i may not have put the ball into the piston slip collar hole, i think the slip collar may be underneath the ball.
Josh Robbins
07-11-2014 12:18 AM
spastic_chicken
05-17-2009 10:14 PM
team
01-02-2009 10:49 AM
