truck wont start after moving the plate forwar
I moved my olate forward this morning about 3/4 the way and now it wont start i check ed were my govenor arm was hiting and it was right on the money but that doesnt have anything to do with it. Any tips to get it to star will help thanks
Take a look at the rod from the shut off solenoid to the fuel shut off lever. If it is slightly bent it will bind and not let the pump fuel. That gets bent real easy by moving the bracket to the side without disconnecting the rod.
A quick way to check is to unhook the shut off solenoid and wire the fuel shut off lever up while you start the truck. If it starts you know where your problem is.
DmaxEter
43
08-28-2012 07:45 AM
natlchamp2k4
11-02-2006 12:18 AM
