Truck won't shut off ???
92 ram 350 diesel,Just did the 3200 spring swap and turned up the pump screw, drove to town shut off just fine, got back home and won't shut off with key??? HELP, Thanks
Originally Posted by iker42
Shut off celinoid probably died on you...Give it a minute for Wanna to chime in and tell u how to run a pull cable....Did you get the truck to shut off yet?
The shutdown lever is at the bottom center of this pic. Push the lever towards the rear to stop the engine.
If you look in the pic Mike posted, the solenoid is towards the bottom, just to the right of center. It has two wires going to it. You just unscrew it with a wrench. It's a lot easier if you trim the rear pump bracket.
Most of the time they die on trucks that have been turned way up. A chunk gets torn out of the tip of the plunger and lets enough fuel pass for the truck to idle.
HAMMER_DOWN
11-14-2007 04:40 PM
