truck will only run for about 30 sec.
Old 10-02-2006 | 07:07 PM
truk's Avatar
fulled tank friday. have drove 46.5 miles it quit!! will run for about 30 secs. then stall again. wait for a minute and crank for awhile it will start again . towed to dealer. but at 530. so no help till tomorrow. any ideas??
Old 10-02-2006 | 07:14 PM
truk's Avatar
since it didnt come up with my name, its a 2004.5 2500 4x4 auto , 600 eng. 64425 miles. ive put 4003 of them on with out any problems.
Old 10-02-2006 | 07:22 PM
REF>Lancer's Avatar
Any chance the fuel filter is plugged?,maybe it has water in the filter,I'm sure that 04.5 has a filter drain.that would be my guess,then maybe a relay?
Old 10-02-2006 | 07:24 PM
XLR8R's Avatar
Fill out your signature so we know what truck you have.
Sounds like fuel starvation due to a clogged filter.
Old 10-02-2006 | 07:27 PM
carcrz's Avatar
I would have said that it may have been plugged up, but you didn't mention that you have noticed any decrease in performance or mileage.
Old 10-02-2006 | 07:31 PM
truk's Avatar
mileage is down alittle just put new fuel filter in 2000 miles ago, drained water from filter and nothing! did use a fram filter
Old 10-02-2006 | 07:34 PM
XLR8R's Avatar
No fuel pressure gauge, right?
Could be the lift pump went south...
Old 10-02-2006 | 07:36 PM
REF>Lancer's Avatar
Yeah,We've never seen that before
Old 10-02-2006 | 07:38 PM
truk's Avatar
nope no gauge! how expencive is that or should i tow home and put in aftermarket?
Old 10-02-2006 | 07:42 PM
XLR8R's Avatar
If it's the lift pump, the dealer will replace your fuel filter housing-mounted lift pump with the newer in-tank lift pump. So far they are holding up just fine, but if you have to pay the dealer you might as well get a Walbro or FASS pump kit and make it even better.
Gauges are very important!
... and cheaper than many repairs.
Old 10-02-2006 | 07:43 PM
REF>Lancer's Avatar
here is a link to FP gauge,I got mine with the Edge Juice W/Attitude...
http://www.blueridgediesel.com/fpgaugekitdodge.htm
Someone might have a better idea where to get one,but this one seems like an OK deal and its not mechanical so there is no mess for the int.
Old 10-02-2006 | 07:46 PM
truk's Avatar
the walbro and fass kits what kind of price? and are they hard to replace?
Old 10-02-2006 | 07:47 PM
XLR8R's Avatar
They should be advertisers on DTR - check the DTR store for prices and photos of what you're looking at installing.
Old 10-02-2006 | 07:49 PM
truk's Avatar
thanks for the help!! i wanted to do some updates but not this way!
Old 10-02-2006 | 07:55 PM
XLR8R's Avatar
Let's see what the dealer says... do you trust this one?
