truck shutting down
Location: In the middle of Weather Dry Creek Farm in Avilla, Arkansas
1 Post
truck shutting down
2000 4x4 auto.
Truck runs fine, then starts losing power and dies. Cycle ignition to off and then restart. Runs fine afterwards. No pattern or particular conditions that seems to cause it. Only code thrown is a 1693 (both computers agreeing that a code was thrown).
Any ideas?
Bruce
Any ideas?
Bruce
Whats the FP at?
Dirty FF?
I assume you are checking codes by some means other then cycling the key 3 times? If not, try Autozone. They can pull codes for you.
Maybe the VP is falling on its face?
Dirty FF?
You must remember the CTD has two controllers that are drivetrain related. The dodge JTEC controller and the Cummins Engine Controller. It would be worth your while to have the modules scanned with a good scan tool.
BAMFT
32
06-09-2005 02:27 PM
Journier
17
06-26-2004 09:51 AM
