truck is overheating in 7 degree weather.
Old 01-22-2009 | 09:00 AM
modifiedzx10r's Avatar
It does it as soon as I start to drive it, first it seems like the temp will never heat up the all of a sudden BOOM, its at 200 degrees, then it climbs up to 245, and it stays there or a min or 2 and it goes back down to 200 and repeats itself. The truck has also been running pretty crappy lately rough idel and just not sounding right, also I have had quite a bit of white smoke on start up and idel even in 20 degree weather, could this be a blown head gasket? I had a problem with a leak a bit ago and tightened up that hose above the turbo and truck has not sucked any more collant from resivor since then. https://www.dieseltruckresource.com/...d.php?t=230383 Refrenced to last post. Im really confused.
Please help
Nick
Old 01-22-2009 | 11:03 AM
johnh's Avatar
still under warranty?? dealer time!
Old 01-22-2009 | 03:01 PM
dozer12216's Avatar
Please help yourself!!!!! Get it to dealer before you really mess something up if not already done. Might be nothing more than air lock in cooling system. Did you think to look at coolant level in radiator while cold??
Tim9712v
07-31-2013 01:11 PM
Ohio_Farmer
07-30-2011 09:14 PM
StrokeThisCTD
06-17-2006 09:28 PM
00turbo
01-15-2006 04:18 PM
Patrick Campbell
03-23-2005 02:29 PM
