truck only turns 2000 rpm
well i jumped the connector off with a jumper wire, and the truck cranked up. but now it only turns 2000 rpms tops. i was gonna unplug the battery cables to reset the computer. dont know if that will help? also, i looked at the slave cylinder, and there is no bleeder valve where it goes into the flywheel. so i guess im screwed? and have to buy a new one? anyone have any suggesstions on these here. i was so close, but now so far away. any help is appreciated
I found this, I don't know if it will help.
http://dodgeram.org/tech/clutch/specs.html
Found this too.
How do you bleed a clutch that has no bleeder screws? dodge 2001 ram 3500?
Answer
Have anyone push the peddle down and hold it and then loosen the line were it connects to the slave cylinder on the transmission and then titen before releasing the pedal
Found this too.
Answer
you know, i almost did just that last night with my roomate. but he has family in, and we "had to get to the bar right then"!! sooooooooooo ill reattack
this evening.
this evening.
jefjsak
01-15-2015 03:44 PM
fishin fever
02-22-2004 08:32 PM
