truck dies at wot
Old 08-21-2005 | 02:29 AM
luke h's Avatar
truck dies at wot
i bought a 98 12 valve today and it will die at wot and when i let off on it if i get on it very hard, it will also die if i hold the brake in drive and tap the pedal, it idles fine and all i just can fig it out
Old 08-21-2005 | 11:51 AM
chop342's Avatar
From: Climax, MI (between battlecreek and kalamazoo)
i would start by changing the fuel filter, the dieing at idle when you tap the pedal is usaully a sign of low idle maybe only a 100 or so rpm. but i would check the return pressure regulator on the return line comming off the pump i have seen that cause the stall at wot and if you let off suddenly. if none of that then i would check the set up on those 4000 gsk's.
Chris
vintovka
04-30-2012 01:38 PM
90 power ram
10-06-2011 09:04 PM
CapnRam
18
06-20-2009 04:48 PM
TNutcher
03-03-2008 01:08 PM
muddin_mavric
14
11-25-2007 09:31 PM
