Truck dead on side of road
Gonna want to run some powerservice white bottle, or some heet, but make sure that you get the heet for diesel.
Your fuel bowl should have a fuel heater. That should help some.
Good luck...
Good luck...
As soon as i can get back to truck gonna try some 911 and new filter.Walked to grocery store -10 and got heet for diesel and dumped in tank ,will adding 911 be too much.Also batteries about dead as kept starting to get off roadway.
If the engine is turning over slower than normal [ weak batteries ] than do try to start , till you can charge them up or at least get a jump , as they discharge , they will freeze , then you will need new batteries .
sorry to hear about your troubles, i dont see why the fuel wouldnt gel in the lines pre fuel heater. that might just be your problem try tom when its a little warmer see what you get... good luck with it!
just got mine running after five hours i did it all then put a torpedo heater by the fuel lines let it sit for 20 min and now she is outside idleing right now hope this helps
