TRransmission won't engage!
Hi again -
-well, I got the 3-pc manifold in, thanks for all the replies / suggestions on that -
NOW...my transmission seems to have a real problem; I replaced the tranny last summer, and have had no problems up until about a month ago. When I start it up and put it into gear - nothing. No fwd or reverse engagement at ALL - yesterday, when going back into Park, I got a grinding sound....after a couple of minutes of going through the gears, and in and out of 4WD, I finally got it to move. The linkage seems to be tight, and the issue appears to disappear when the transmission is warm. Fluid level is good.....
'99 Cummins Quad Cab Long Bed, auto-trans...
Almost sounds like your transfer case. That grinding you heard was probably your park pin trying to engage while the tranny was spinning. I wish I could help more.
Was a new TC also installed with the new/rebuilt transmission?
If not, could an old worn TC be the problem because it cannot pump cold fluids at the correct pressure?
Bet it's the filter
Diesel shop owner friend has told me that many of the rebuilt TCs on the market are full of manufacturing trash and the filter should be changed after around 1000 miles. Without naming names the trash statement includes the most popular aftermarket auto trans sources out there. He has received some that were so dirty that he's sent them back.
I second the filter statement-
because on all new frictions you do install in an AT there is a kind of peach fuzz that will wear off very soon (like 200-700miles) and will clog your filter. And a clogged filter will be very noticeable in the cold when the fluid is still viscuous and won't want to go through the filter media. There is only suction on this side- but a clogged filter will also increase the likelyhood of slippage since it won't let enough fluid through to build decent pressure. Slippage makes for more dirt entering the fluid.
Maybe you should also try to let the truck high idle in neutral for about 50-75 seconds when cold. The TC will not fill in P on a stock tranny. (No circulation through the cooler circuit with the stock VB). Shifting around with a weird acting tranny is not to be recommended.
Just my 2c
AlpineRAM
Just my 2c
AlpineRAM
Alpineram is right about letting it idle in neutral for a minute to let the TC fill and lube the inards. However, the "grinding" sound you hear makes me wonder about the transfercase. In order to get that grinding to take place while sitting still, the transfercase must be out of gear in order to let the output shaft in the trans to spin. I would check the adjustment on the T'case to make sure it is in gear all the way.
Dave
Dave
BigDodgeBigHart
04-13-2007 10:26 AM
BigDodgeBigHart
04-13-2007 09:18 AM
lightningfast2
15
03-11-2005 01:30 AM
