Trouble codes 98/ 24 valve
I am at work and a friends truck was running bad. He got some codes and wants to see if anyone can help me out. codes are p1693 p0236 and p0238. he says the power is down.
Not sure I have correct code list, but here it is.
p1693 DTC Detected in ECM or PCM
p0235 MAP Sensor Too High Too Long
p0238 MAP Sensor Voltage Too High
Hope this helps. Good Luck, not sure what the cods all mean.
p0341 Camshaft Position Sensor Performance / Rationality
p1690
p0230 Fuel Pump Relay Control Circuit
I think thats right??
To kelley15 I would say your friends map sensor is bad
p1690
ridlangus123
12-30-2013 08:36 PM
exwrestler
02-05-2010 09:34 AM
sallyman1
08-26-2008 06:20 PM
