Transmission Temp. Light Keeps Coming On!!!
Three days now .after 10-12 miles trans. temp. light is coming on and automaticaly engaging tow\haul mode. Changed trans filter -blew out cooler/lines-disassembled/cleaned air cooler thermostat.. Fluid level seems fine.Fluid does not seem real hot when checked .I"ve felt much hotter under normal operation.Could this be a temp sensor problem? Need truck DAily Any Help is GREATLY APPREICIATED!!
Check for restricted cooler flow. Take line off at rear of tranny. Must flow in excess of quart ATF in 20 seconds. Don't empty tranny and can be very messy.
Possible failed trans temp sensor (or shorted wire) in tranny and part of governor pressure transducer.
benny
07-05-2005 03:55 PM
Amish hauler
02-29-2004 10:26 PM
