transmission replacement?
I'm almost ready to drop my slushbox. My question is how do I access the torque converter bolts? through starter hole or the access plate on the left side. and how do you turn the engine to get the rest? thanks
use the access on the "right" side of the trans adapter. there is a plate with two 10mm bolts holding it in place. Use a prybar to roll the engine over from the bottom where you have the lower inspection cover off. Hope you are putting a "good" trans in.
Big Rig
08-30-2007 06:07 PM
AggiePhil
17
10-19-2006 06:18 PM
MasseyMan1089
08-04-2005 10:27 AM
