Transmission Questions, need info asap...
Hello all and thanks in advance. I have a 2003 2500 , just figured out it is a HO motor. It is an automatic, the glovebox says 4speed auto, but i count four shifts, meaning 5 speeds (or am I counting OD also?) anyhow...
I want to change the trans filter and fluid (drop pan, drain, replace filter and refill).
I need to know:
1) What transmission I have (how to Identify it)
2) What Fluid to use (pretty sure mopar+4)
3) How much fluid to purchase
Thank you again, my email is MisterT_1973 at hotmail dot com,
and my AIM screenname is MisterT1973.
Travis
I need to know:
Travis
You need ATF+4. It is a 4 speed tranny, including OD. The extra shifts you feel are torque converter lock up in drive and OD. You'll need 7-10 qts. I would recommend buying 3 gallons and keep the other for spare.
Josh
www.dieselperformancesolutions.com
Josh
They switched from the 47 to the 48 in the middle of the '03 model year. So if yours is an early '03, it's a 47, late it's a 48. Most of the differences are internal. Ask the parts guy at the dealership to give you the readout on your vin. It'll tell exactly what your truck had from the factory.
I need to know:
Travis
I need to know:
Travis
1stTimeAround
09-05-2006 04:15 PM
Hoss
27
05-13-2003 10:55 PM
Hoss
05-13-2003 11:50 AM
