transmission line quick connect leaking
I have the stock quick connect fittings (they are the metal clips, not plastic)on tranny hoses going to the cooler. One was leaking and I replaced it, but it still leaks at the fitting, just like the old one. I am able to slide the fitting back and forth maybe a 1/4" when it is on, both the original and the new one do this. Should they be loose like this? Does anyone have any ideas. I do n't have the money to get the dealer kit and replace all the lines. Thanks
Do not even think about the dealer , look in my gallery and see what i did , total cost was less than 100 bucks Canadian.if you search my threads/posts you will find my write up on it.
ripping r
01-05-2010 06:58 PM
RHC
10-26-2009 11:17 AM
chucktownsend5
04-03-2005 07:53 AM
