Transmission indicator doesn't highlight park after valve body install?
Can't figure out what the deal is. Feels like it goes into park but it doesn't highlight it. Does all the other gears fine.
Drove it about 35 miles and seems great
A little firmer shifts. Seems much more responsive. Transmission temp seems to be down about 5-10 degrees
Pretty happy with it.
Now, it goes into park sometimes and other times you gotta go down to to 1 and go fast to park in order for it to go in.
Is there adjustment somewere? I don't see anyway to change this?
Thanks
Thanks
Shift cable is adjsutable. Have someone move shifter and see what moves at tranny. That cable has a adjustment somewhere, generally where mounts to tranny. Buy a FSM
Put the transmission selector in P. Up under the dash if you follow the selector cable out of the firewall up to the steering column, you will find a white plastic clip in a retainer. The clip pushes up. If it has not been done before it might be a little stubborn.
Now, with the clip up, go down to the transmission and grab the selector lever and push it fully to the rear. Next, try and rock the truck to insure the lever is fully in the park position.
Next, push the clip under the dash back in.
Done. Your selector linkage should be adjusted.
DieselGuyMike
15
11-30-2007 09:40 PM
