torque converter bolts
Old 10-05-2006 | 01:10 PM
94/300k2500's Avatar
I'm in the middle of a 5 speed swap, and got down to the bolts on the t/c to flexplate. How in the world do you get to these. Thanx for your help
Old 10-05-2006 | 01:48 PM
mr T's Avatar
drop the access cover on the bottom to get access to the plate so u can turn the plate over with a screw driver
THEN
on the passenger side of the bellhousing..looking towards ur rear wheels is a small metal access cover...maybe 3 inches in ize thats all...it has 2 bolts...remove the bolt and u will have a circular hole...thats where u put the socket on the bolt...
back under the first access cover...turn the plate over until a bolt lines up with the arrow thats there...when it lines up, u will have a bolt in the hole
wyattearp29
11-22-2009 05:18 PM
gorms
09-01-2008 10:07 PM
maddog1927
07-19-2007 08:05 PM
mainer
07-17-2007 07:13 PM
boostedte37
07-20-2005 07:56 AM
Quick Reply: torque converter bolts
