Thuren Track & Cross Bar Alignment
Help
At dealer now for a front end alignment. After having DW Multiple times I have installed Thuren Track and Cross bars. I have replaced all 4ea ball joints prior to this alignment. Service tech says that there is no way to set the camber and one side is way out. Caster is out also and should be able to be adjusted to proper settings. I gave then the specs off of this site for adjustments i required. I requested zero toe or as close to zero toe as possible without going negitive.
Question is there any way to correct the camber on the passenger side? Help before they are done.
Thank You
IC
Thank You
IC
Still Veiwing, Not logged in while not at Computer.
Please post any help would be great. Veiwing as a guest as I am walking between computer and Service Dept so no one can post under my name.
Checking every few min.
Thank You
IC
Thank You
IC
IC Front Alignment
Specs i gave service is
Caster
-3.2 left
-3.5 right
-.3 cross
Camber
-.10 left
-.10 right
0.0 cross
Is this correct?
Service tech said no way. they could go positive to those specs but not negitive.
Help
Thank You
IC
Caster
-3.2 left
-3.5 right
-.3 cross
Camber
-.10 left
-.10 right
0.0 cross
Is this correct?
Help
Thank You
IC
The camber on your axle would not be affected by the Thuren products, so the problem with the axle is likely the source of your wobble in the first place. This would have been a manufacturing defect, unless you have been pounding the truck and bent the axle.
I am a bit surprised your front end shop does not know about the offset joints for Jeeps and Dodges. They come in various degrees of inclination to solve this sort of problem. However, first check to be sure you housing is not sprung, because it can be easily bent back with a good machine.
Thanks
I did not know about the offset ball joints. I just replaced the originals with factory stock ones that have been modified to have grease zirks.
No pounding on the front end. have not had the time for off roading yet.
Thanks for the info. Where can the offset ball joints be purchased?
Thank You
IC
Thank You
IC
Check this out:
Upper Ball Joint
FRONT SUSPENSION
4500LB DANA 60 AXLE - ADJUSTABLE BALL JOINT ALLOWS CAMBER ADJUSTMENT TRW P/N# 104342
Straight from Federal Mogul. If you can't find that P/N# most parts stores should be able to interchange it.
Upper Ball Joint
FRONT SUSPENSION
CTD2001
08-22-2009 10:03 PM
silkywoods
17
12-03-2007 05:09 PM
getblown5.9
25
12-08-2005 11:52 AM
Fishbait
12-05-2005 09:17 AM
