sudden power loss ,12 valve
I need help diagnosing a sudden loss of power on my 12 valve. Driving home from work today , the go peddle went dead. No smoke, no exhaust heat, low boost. Idles smooth & sounds normal. the first thing I did was change the fuel filter , it had no effect. thanks, doug
A boost leak would give smoke, wouldnt it??
sounds like a fuel pressure problem to me - do u have a guage setup to measure fuel pressure??
How about the overflow valve? Have you changed yours lately??
not boost
boost leak would cause high EGTs & smoke. I got so impute on the 12 valve thread, he suggested the fuel shutoff solenoid isn't pulling up all the way. Sounds like a a good bet I will check it in the morning . thanks for helping, doug
Dr. Evil:
Sorry, you're right about the smoke with a boost leak. I missed that in his original post. Time for glasses or a retake at the "Evelyn Wood Sped Reding" course. A fuel problem is more likely. Hope you get it found and fixed easily.
My vote is also for the shutdown solenoid not pulling up all the way. However, if the wastegate actuator diaphragm ruptures and leaks, or the aneroid line breaks, it will cause a boost leak AND loss of fueling, because the aneroid in the pump won't receive pressure.
jasonlb
01-15-2005 11:11 AM
