Stranded outta town with throtle problem
Sounds to me like you have a ground problem. I would try cleaning all grounds (not just battery cables) under the hood, as well as checking and cleaning all related connectors. See if that helps, and do unplug the Comp to see if that makes a difference as well.
mishkaya
mishkaya
I am convinced it's either APPS related or another electrical issue. I would suggest sending a PM to member Timbo01 as he has a fair amount of knowledge with the APPS and might be able to help you directly troubleshoot.
Good luck
mishkaya
Good luck
mishkaya
DmaxEter
11-09-2005 03:25 PM
mikal711
02-09-2004 07:55 PM
