Stock Air Box Cracked
When I pulled the cover off the stock air box the lower part cracked badly. The crack runs from the plastic tabs facing the front of the truck, down to the center of the bottom part. The local Napa cannot get me a BHAF untill the middle of the week. The seal around the filter looks o.k. because the top of the filter box holds it closed. Should I be o.k. to drive the truck untill the BHAF gets here? I need it to haul an 11,000 pound trailer about 120 miles tommorow.<br><br>
Re:Stock Air Box Cracked
Hmm.... I guess I never thought of duct tape, or maybe I could use some strong epoxy. I kinda freaked out when it happened and ran right to my computer to call for help. Besides, the big peice that fell out of the bottom should help air flow a little. ;D
I'd use duct tape aand go to the dealer ASAP to get it under warranty- I think it should be covered as long as you didn't mistreat it or have a chrome exhaust tip that voids all your warrantys <br><br>If you try to repair it with some epoxy the dealer could get you into troubles ( not qualified rep. attempt )<br><br>AlpineRAM
I think I am just goining to forget taking it to the dealer, the local dodge place isnt certified to work on the Cummins trucks, so they will not touch it. I am just going to wait untill Wendsday and get my BHAF.<br><br>Thanks for all your input.
I would use Duct tape for the time being. Even if they won't work on it, they should get you one under warranty. Then you will have a good one if need be.<br><br>Mike
Well, i just spoke with the closest dealer that is cummins certified, the warrenty manager said it would be covered. However, when I ordered the part, the parts manager was a real jerk. Oh well, hopefully they wont try and back out of the warrenty.<br><br>Thanks Again,<br><br>Matt
klx650a2
04-20-2009 06:25 PM
HeberRam
25
04-23-2003 04:06 PM
