Starting Problems 2003 Diesel
Having problems with slow starting in 2003 Dodge 3500 Diesel. Cranks good. Thought the lifter pump was going bad. Repalced a pump (module??) in the tank. This did not correct the problem. Am now being told that was the wrong part (All coming from a Dodge Dealer in Tulsa, OK) and an adapter kit of somekind is needed instead. Of course since the pump was installed, it is non-returnable for full credit of $350+. Dodge dealer says there are 7 of these parts on order and does not know when they can get one. Have other Dodge owners come upon this problem? I know of 3 different trucks within the last 4 months that have had similar problems, not a warranty item, and apparently not a recall item. It seems is there are 7 of the same parts on order at one dealership, that should tell Dodge something. First they sell the wrong part, tell me it is the wrong part, and tell me I cannot return it for a refund. This situatuion does nothing for the integrity of Dodge.
to me it still sounds like a bad lift pump. On your 03 the filter is mounted on the back of the fuel filter housing not in the tank. No the dealer cannot get the old pump they have to do an in-tank retro-fit with the new pump they are selling now. Dodge started using these on 05 trucks. Should be a warranty item if you are still under the 100,000 mile engine warranty. If not best bet is to go with a Walbro set up for under $400. www.glacierdiesel.com Great product and no more fuel worries. To do some more troubleshooting is check for codes or check fuel pressure before cp3 should be a minumum of 5-8 p.s.i. You running any mods right now or are you stock?
bdewey: Was "on your 03 the filter is mounted on the back of the fuel filter housing" a typo or am I once again totally lost. Sorry to butt into your thread slgorton but I have been trying to figure out where my pump is located (just in case) with a build date of 03-04-03. I see some sort of a gadget behind the filter but dont know if it is just fuel filter stuff or if its the lift pump itself (I am used to older gas jobs with a single mechanical pump). Sorry again for butting in without helping with your problem.
yes the lift pump is on the back of the filter up until the 05 model year when they started putting them in the tank. It is a black cylinder attached to the back of the housing. The main reason they failed is they had to pull the fuel from the tank instead of push like the new in-tank set-up.
Thanks for the info people. Clarified things for me. So, if mine goes out should I plan on going with an Air Dog or other good brand but not go with an in tank unit? slgorton: Did I understand correctly that they replaced your stock LP with an in tank LP? You refered to a "module" and I got confused (happens easy to me).
I am having trouble with my 03 HO 6 speed 4x4 75000 miles still under warranty. Engine surging above idle and through gear changes until I get to about 60 mph. fuel mileage dropped from 27 to 17.4 when engine started this surging problem. Could this be a fuel pump problem? Dealer could not trouble shoot this problem.
Bark if you are still under warranty of 100,000 miles the dealer can install the in-tank conversion if they are convinced that the LP is the problem. Is a decent conversion if you stay stock, but would just go ahead and upgrade with an Airdog, Glacier, or FASS set-up. Choice is yours but my money is on the Glacier set-up.
Elkchaseryour suring issues can be a lift pump going out or your FCA on the CP3 pump. Sometimes your FCA will gum up and not allow it to operate smoothly. Also check your filter? When was last time you changed it? Should be done at least every 7500 to 10000 miles.
trsaggie01
12-08-2010 09:00 PM
Big Mac
01-03-2010 11:39 AM
ollie32
11-08-2007 09:30 PM
