Shut down soleniod
Old 11-12-2008 | 03:14 PM
Oscar1017's Avatar
Shut down soleniod
Help where can i get i shut down sloeniod for a 1998 ctd 12 valve??? It went out the other day and cant seem to find one locally, Please help me out or what can i do to fix it thanks
Old 11-12-2008 | 03:19 PM
Dave Miller's Avatar
Larry B's has them for $229 here:
http://www.fostertruck.com/dodge/default.htm
You can also get them at www.Genosgarage.com
Are you sure its not a fusible link or relay? Check Larry B's site for troublshooting hints and schematics. I cleaned the plunger and bore on mine and lubed it with silicone spray and it fixed mine. Then the relay went and that fixed it recently.
Dave
Old 11-12-2008 | 06:04 PM
infidel's Avatar
DON'T REPLACE THE SOLENOID!!!
Likely nothing is wrong with it unless it is very visibly burned up on the outside.
The solenoid is probably the most needlessly replaced item on a 12 valve, expensive too. The solenoid is a very simple, sturdy device that will easily last the life of the truck. It either works or it doesn't, there is no such thing as one getting weak.
The problem is almost always a corroded blue wire from the driver's side battery or a bad relay on the firewall. The rubber boot that protects the solenoid can fall apart allowing gunk and rust to bind the solenoid, clean it up and replace the boot.
Relay and boot are availible for a good price here http://www.fostertruck.com/dodge/default.htm
Old 11-13-2008 | 01:34 PM
Oscar1017's Avatar
oh ok yea ill check out the realy and wire after school once i get home thanks alot man
Muddin_dude06
06-20-2007 10:56 PM
chadwick
05-18-2006 06:31 AM
tyssniffen
03-26-2006 07:15 PM
93' Shorty
10-28-2004 01:48 AM
Got Smoke?
05-27-2003 09:13 AM
Quick Reply: Shut down soleniod
