Seat Belts
Originally Posted by phox_mulder
The seatbelt locks need voltage.
Either the voltage locks them, or unlocks them. (can't remember which)
Check the connections.
Good luck!
I'm still fighting mine. I put voltage to it. The pink wire is the hot one, and while the pass. seat comes out just fine, the driver's only come out 1/3 of the way and locks. When I pull the driver's out until it locks it also locks the passenger seat. I can't figure out of I have a problem in the seat or need to hook up more wires to the control until under the console.
If I bypass the control unit and put voltage straight to the orange wire on the driver's seat it will come out all the way. I don't want to use it this way because it bypasses the control unit which may save my butt one day. On top of this, the driver's seat has 3 wires, vs. the passenger's 2 wires. The additional wire on the driver's side is green, and when I cut it neither seat belt would work any more. I put it back together and am back where I started.
STILL looking for a wiring diagram for these 2001 seats.
Chris
Chris
Try resetting the truck by disconnecting the battery for an hour. Under curtain circumstances (like unplugging the seat belt power) the truck thinks its been in a roll over accident and you need to reset it.
Don't ask me how I know this.
AggiePhil
02-08-2005 03:31 PM
