right wheel wheel stuck
slow leak in right rear wheel on 04.5 srw 3500. jacked truck up took off lugs, wheel is stuck on hub, cant get it to budge, will not come off! am i missing something?
Josh
Put the rim and lugs back on slightly loose, then drive around the block slowly.
By the time you get home, it will be loosened up.
Or put the rims and lugs back on slightly loose,
jack up the rear end, start truck and put it in gear,
get the rear wheels turning then slam on the brakes.
phox
Edit to add:
Make sure the truck is supported on jackstands, not just the jack.
Ed A.
phox
Edit to add:
Ed A.
phox
Edit to add:
Ed A.
phox
Edit to add:
Ed A.
I'll make sure I specify that next time I give out that advice.
phox
Mine were stuck on the first time also. Once I finally got them off (with a sledge) I sprayed the wheel where it mates with the hub with white grease. The 2nd time I took them off the wheels came right off like normal.
I would suggest using antisieze on the hub surfaces after anyone takes these wheels off. I did a rotate on my truck with 5K miles and two wheels had to be removed via sledge. I have the alloy wheels on my truck
birdboy
12-12-2018 09:02 PM
birdboy
04-21-2012 09:44 PM
