replacing overdrive unit!??!!
iam tryin to install my over drive unit back on my 2000, i can get the park rod in it but the overdrive unit wont slide completly against the transmission like it did before. Im putting it back on because i cracked the case on it. anybody got any links of how to install the over drive unit back on the truck, i need details here.
OD piston may not be indexed into dowels. OD spaced and bearing may be mispositioned. Splines may have become misaligned at overrunning clutch inside gear train. There is special aligning tool at dealerships that is more critical than a intermediate shaft.
Sometimes it takes a little wiggling and wrestling to get it the last 1/4 inch.
DTR's 'Go to Guy'
You can also take the clip off of the park rod on the top of the valve body and move thr rod forward. It is a real pain, but it can be done. Move the park rod forward and then put the overdrive on. After geting a few bolts snugged up, rotate the rear shaft until the park rod will go back into place.
NJMurvin
03-16-2011 12:28 PM
