Replaced Starter contacts, now lift pump not working?
I replaced the starter contacts in my truck this afternoon. Also did the oil and the fuel filter while I was under the hood. Everything went together OK, or so I thought. Now it turns over great, but I have no fuel pressure. When I first cranked it, it caught before I could let the fuel filter get all of the air out. Then it died. Now I can turn it over fine, but the buzz from the lift pump is not there when I bump the engine. Before today I was getting about 11-13 psi on the LP.
The LP was replaced about 30K ago, and has been steady ever since. When the first LP went out, it ran erractically for weeks and never really just went dead.
Any thoughts as to what and how to check? I have a spare LP somewhere, but I really don't relish another afternoon with the hood up. Could I have somehow knocked a wire loose to the LP?
Thanks for the idea ds1rider,
I am settling on miracles as the answer because this morning, all was right. Turned the key, got a buzz from the LP. About 3 cycles of bleeding air from the filter canister, and a 10 second crank, and it runs fine. Same pressure as before the new filter.
Whew! I really hated replacing the LP a couple of years ago.
Sleigher
05-04-2017 02:12 PM
buckman361
11-13-2008 09:54 AM
buba1960
02-19-2008 03:27 PM
MJR
03-16-2003 08:26 PM
