Rebuilding Starter
Old 10-06-2005 | 12:24 AM
zack_76401's Avatar
From: Lingleville TX but active duty Air Force all over the world currently
Rebuilding Starter
Hey guys, I got my starter kit in the mail today that i ordered off ebay.
For 29.50 I got a new plunger, return spring, gasket, and 2 PAIRS of new HD contacts. Guess I'll throw the extra set in the glove box.
A few questions, Do i need to clean anything else up while I'm in there? Do I need to put Di electric grease on enything?
The copper parts I got are a very good qaulitybut have a few fingerprints and what not on the that could lead to corrosion. Should I clean then up and what should i use?
Any thing else i need to know before i start into this....Im workin nights right now so i have to do it in the am after work then try to get some sleep to be back at work at 6pm.....
How long will this take?
Thanks in advance guys, Zack
Old 10-06-2005 | 10:10 AM
infidel's Avatar
Good instructions here http://www.fostertruck.com/contacts_install.htm
Should take an hour or less
Old 10-06-2005 | 11:55 AM
smokeyram's Avatar
dont loose that little ball bearing that rides on the plunger head.
I had the whole thing rebuilt, then i saw it on the floor, i never saw it come out
Old 12-13-2005 | 05:25 PM
jon96ctd's Avatar
i got lucky with the little ball, landed on a papertowel at the top of the 40 gallon trash can.
just ordered the super contact kit, my bad batteries worked the contact and plunger hard on mine. with big new contacts, bigger 2/0 cable and bigger batteries it should start very well now!
Old 12-13-2005 | 05:28 PM
Geico266's Avatar
Make sure the contacts are flat against the bottom of the starter. I think the directions state this also.
Old 12-13-2005 | 07:37 PM
kd460's Avatar
Clean up the armature and field with some wd-40 and clean rags. Get into the gear end of it, clean up the gears and relube. You will also see a funny looking bearing, I think it is 3 rollers and a plastic holder, clean and lube. I just used some mobil 1 grease is all areas that I felt it needed it. Pretty straight forward. There is a link on how to somewhere, I'll see if I can find it.
Heres the link: http://kydtr.com/iboard/index.php?showtopic=3755
Heres another: http://www.fixinrams.com/id11.html
RamDodgeSam
10-05-2014 02:53 PM
FMB
11-14-2010 10:09 PM
wcbcruzer
01-30-2008 01:36 AM
wcbcruzer
10-12-2007 09:18 AM
Paradise Racing
01-18-2005 10:08 AM
