Ramifier Throwing codes
I just installed a TS Ramifier on my 05. I have a superchip Flaspaq installed. My check egine light is now on and I'm getting the following codes:
P0122-Intake air temp circ low
P0652-sensor reference voltage B circ low
P2127-throtle/pedal position sens/sw E circ low
P0069-map barometric pressure correlation
Do I possibly have a bad Ramifier? Help me please!!
Thanks,
D
Thanks,
D
The first thing you need to do is disconnect the negative battery cables, turn on the lights, and remove any cell phone chargers or other chargers that may be plugged into the system, and then go spend a half hour at the nearest bar.
Once the air bag caps have fully drained, turn everything off and remove the Superchip FlashPaq, then reinitialize your full system and take it through the entire start sequence - wait for all timers and lights to fully cycle before starting - and then turn off the engine and let it set a few seconds.
Start the engine and your problem should be solved.
If you have the hots for the Superchip Flaspaq, call Steve Brown of Torque Max at 870 404 6740 and discuss compatibility. It is my belief that the Superchip conflicts with the Torque Max and that you have to use a passive controller that does not rewrite MAP and Fuel Pressure sensor signals, such as TST's if you want to stack processors with the Torque Max.
By the way, if you did not do the very first instruction when you first installed the Torque Max, you could have damaged your PCM and may need a new one.
Thanks,
D
Thanks,
D
Thank You RCW I'll Do that tomorrow. Should I put the truck back to stock with the Flashpaq before I Drain the batteries? Should Ialso remove the Ramifier? Also my Ramifier is the non adjustable one.
Thanks Again,
D
Thanks Again,
D
Dalbery
01-24-2007 08:59 PM
ssleeper94
11-11-2005 11:47 PM
gatf4
03-22-2005 02:00 PM
