projector headlights
i put in a set of projector headlights from k2 motor and i am wondering if a canadian made truck with day time running lights will effect how these lights work cause i am not getting full power for a high beam. any help is appreciated
They're most likely set up for a 9007. Does your high beam indicator stay on all the time? Do you have about half power on both lights when you hit the high beams?
Your ground pin and low beam pin need to be switched on the socket of your truck. Or, cut and splice the wires.
Doug
Doug
Jc9995
36
10-31-2006 10:15 PM
Checkmate
10-18-2006 09:23 PM
BEHRMAN
32
10-24-2005 11:14 PM
03CTDCO
13
09-01-2005 11:47 PM
