Power Loss, won't rev - Pls HELP!
- a friend of mine has an '01 HO / manual tranny which starts up fine, but will not rev at ALL above 1800-ish RPM, no matter how much throttle he gives it. He says it's giving him a LOT of BLUE smoke when he tries to raise the RPM's. This goes on for many minutes, when it will suddenly "catch" and rev just fine.
Any ideas about this? I told him to pull the IAT sensor and see if it's fouled, and swap in a new fuel filter; He already pulled / cleaned / oiled the K&N air filter he's running....I don't think he's trying to rev it when it's cold, but....
This apparently started after he filled up at a local Chevron - I (jokingly!) asked him if he filled up with gas (which would disable the engine entirely, I believe?)
I am not sure if the '01 will post the codes with the three-turns-of-the-key trick - will it? If so, I'll let you guys know if any codes are showing.
His truck is staying parked - a BAD situation for him - until we can get this solved - please help!
Thx / Rauschbo
Thx / Rauschbo
Re: Power Loss, won't rev - Pls HELP!
Originally posted by Rauschbo
-This apparently started after he filled up at a local Chevron - I (jokingly!) asked him if he filled up with gas (which would disable the engine entirely, I believe?)
Or, the in ground tank could have been topped off with unleaded by a unattentative tanker driver.
If it started right after he filled up, that could very well be the case.
Easy way to tell is give the tank contents a sniff, any gasoline will be easily sniffable.
phox
Well, we're pretty sure it's not gas, and the air filter was cleaned - he also checked to see if the turbo was "sucking", and it appears to be fine.
Anything else to check before he spends $?
Thx for the replies -
- if it is the LP or IP, why does it run fine after a while?
I'm slated to go help him troubleshoot, we'll start by again checking the K&N airfilter, the fuel filter, clean the IAT, check the MAPP sensor, check the PCM connection (seems his AC is acting up now, too), TPS.......if we're still seeing the issue, I'll give a shout -
- thx again, and if anything else occurs to anyone, I'm all ears!
Rauschbo
P.S. - Merrick, you still in business with the partnership you had going about a year ago?
Rauschbo
RHC
08-12-2019 03:32 PM
chadpatten
27
11-30-2005 10:31 AM
